CMTP02 – disassembling this solar charge controller
I want to share inside look at cheap Chinese solar charge controller CMTP02 (CMTP-02). I have a 30A (charging current) variant, but it has also 5A, 10A, 15A, 20A versions. It should be a PWM controller. Maybe even not that (like Didier pointed out in the comments section). I have not learned all the terminology regarding solar controllers and how to identify their type. But one thing is sure- MPPT should have DC to DC converter inside it (am I right?).
Some eBay users sometimes put MPPT int the title – but it’s misleading. It’s not that kind of charger. I thought also that it is but was bit disappointed (didn’t do my homework before buying it). Well- the price should ring bells if nothing else does. Anyway- I hope this post helps other people to choose their controller when stumbled upon this cheap charger. And get some inside info before considering to buy it.
Please note this post is written in the year 2014 and it’s possibly not that accurate anymore. They probably have changed their design also by now. But the basic concept is most likely the same. I If anyone can confirm please feel free to comment.
There is also pictures of 5-ampere version posted by Didier. You can look at them here. Also one user manual (10A version I suppose). It uses irfb3206 mosfets to do the heavy lifting as seen on photos.
How CMTP02 works?
If you are looking how this charger actually works you are in luck. Alan reverse engineered a 20A variant’s circuit and operation. You can read more info from his comment below from his website.
What is inside of CMTP02
Well, check out these photos. I just opened it up and made some shots to overview it’s content.
CMTP02 30A Solar charger controller backside opened
Here you can see that mosfets are heatsinked to the backside (but not firmly). Just little contact with pressure. Someone who has used it with higher loads can comment- is it enough and how well it works.
CMTP02 30A Solar charger controller top view
CMTP02 30A Solar charger controller frontside
CMTP02 30A Solar charger controller main board, chema, circuit, front
CMTP02 30A Solar charger controller chip
Controller chips
A closer look at chips on board. Probably controlling? I didn’t look up their datasheets.
CMTP02 30A Solar charger controller mosfet irfb3206
Mosfet irfb3206 closer look
Here we can see what kind of mosfets are used to drive current. All three was the same (if I remember correctly)
And finally- picture of manual. Just in case.
CMTP02 Solar charger controller user guide manual
Comments
  1. By Gabor Gregusik
    Reply
    • By Janar
      Reply
  2. Reply
    • By Janar
      Reply
  3. Reply
  4. By Richard
    Reply
    • By Janar
      Reply
  5. By Richard
    Reply
  6. By Richard
    Reply
  7. By Henk
    Reply
  8. By ivan
    Reply
  9. By ivan
    Reply
  10. Reply
    • Reply
  11. Reply
  12. By Hanseonho
    Reply
    • By Janar
      Reply
      • By Han seon ho
        Reply
      • By Han seon ho
        Reply
  13. By Han seon ho
    Reply
  14. By Markus
    Reply
  15. By didier
    Reply
    • By Janar
      Reply
      • By didier
        Reply
        • By Chuck
          Reply
          • By Chuck
  16. By majid
    Reply
  17. By Mark
    Reply
  18. By Mark
    Reply
  19. By JakDac
    Reply
  20. By olle
    Reply
    • By Janar
      Reply
  21. By Colin
    Reply
    • Reply
  22. By six
    Reply
  23. By Lanre Oyelade
    Reply
    • By Janar
      Reply
  24. By sanjay
    Reply
    • By Janar
      Reply
  25. By Allan Jones
    Reply
  26. Reply
  27. By DG
    Reply
  28. Reply
    • By Janar
      Reply
    • Reply
  29. By Alan Seidner
    Reply
  30. Reply
    • By Alan Cashin
      Reply
Leave a Reply
Your email address will not be published. Required fields are marked *
thirty four + = thirty eight
By continuing to use the site, you agree to the use of cookies. more information
The cookie settings on this website are set to "allow cookies" to give you the best browsing experience possible. If you continue to use this website without changing your cookie settings or you click "Accept" below then you are consenting to this.
Close
